Insert effects and Plugin Delay
  • Thread starter Thread starter Ace2000
A
Ace2000
Hey there, I'm using CUbase 5, I have the drum module LM-4 too...
what I want to do is apply compression to the snare drum.I guess I must use it as an insert effect, but when I turn it on, the snare goes slightly out of time with the rest of the music. When I turn it off it's normal, even though i have reverb and I never have had delay problems with my plug ins till now.
In the Audio Systems options, I enable the PLUG IN DELAY feqature, but it still is out of time...
anyone know what to do?
All I want to do is compress the snare drum without adding it as a master effect. I just want it as an insert, but is this delay thing a probalem with you all too?
Im using a Pentium 4 with 40 gig hard drive, had no probnblems with th eCPU, the meter is low.
what gives?
sounds bizarre..you only have this problem with a particular plug in?
