Hello, sorry if this is a cross post, I can't find my previous message and it's directly related to Cubase5, so if you seen this in MP3 forum, I apologoze.
Okay here's my dillema. I'm using the drum synth LM-4 and I want to add compression to the snare. When I add compression as an insert effect and turn it on, there's a slight delay knocking the snare out fo time wuth the song. turn it off, it's normal again. And only as an insert effect...my send effects and masters dont so this.
The manual said to g intop Audio Systems dialog and check the PLUGIN DELAY box, i did to noavail...still there knocking my snare out of time....
what can I do? ALl I want to do is compress the snare with the VST compressor plug-in.
