Hi, I really hope I make sense whilst explaining this because my brain is hurting right now!
I am recording acoustic (classical) guitar, here is my setup,
Hardware: AKG C2000b large diaphragm condenser mic, Shure SM57 dynamic mic, Alto Zephyr ZMX 52 audio mixer and this goes into my laptop via an audio interface.
Software: Adobe Audition CS5
Now Adobe audition insists that the input and output sample rates are matching before you can begin recording. So I then go into my speaker and mic setup properties (via Windows 7) and set them both to 16 bit 44100 khz and then set the sample rate in Adobe Audition to 44100 khz.
The problem is that this set up gives me a ridiculous amount of static, but then 5 minutes all the static is gone, and then maybe 10 minutes later the static is back again. What is going wrong?
I am assuming that this may have something to do with the sample rates (which I think are too low) because as soon as I start messing around with the sample rates it will correct itself, but here is the problem, In adobe audition it lets me take the sample rate to 192000khz but in windows 7 will only let me take it has high as 48000.
I hope I have made sense.
Thanks
Dan
Thanks
Dan
