G
Geoff_T
tubedude said:Question for Geoff...
Will the new 8 channel console be affordable for us homereccers or is it going to be a $10,000+ kind of deal?
Xformer preamps?
Give us some info, please...![]()
Hi
We still have to work out the price but I can confirm that it will be a fraction of the $10,000 figure you quote there!
I think that it's important to note that it's a line input mixer so there aren't pre-amps in it, although there is a stepped Elma gain switch with a range of +10 to -20dB (with a further +10dB in hand in the fader).
I have several concepts for its use...
For a start, pre amps and eq aside, it gives you as much (if not more) than a regular console would.
i.e. Input gain control, input level indication, pre-fade insertions on inputs and outputs, 4 bus, channel mute and solo-in-place, plus a full monitor/meter system with real Sifam VU's and a phase meter (to confirm mono compatibility, especially on car radios!), stereo playback to check your recording, stereo effects return, two switched monitor outputs for two speaker systems, and even a stereo headphone driver.
This could hang on the outputs of a digital editing system and provide the mixdown to stereo. It is easily expandible to any number of channels and the add on units are less expensive as the mon/meter on the outputs is not fitted. For a small home studio it provides a perfect solution... I provide a 25 pin Cannon D as well as XLR's for the inputs and each channel has pre-fade insertions and channel outputs.
Now, if you want mic pres with EQ's to go with it, the GTQ2 has two outputs per channel and one of those outputs was designed to drive our mini-mixer. The mini-mixer is 3U high and with 8 channels of GTQ2 you would have an 8 (or more) into 4 that's 7U (12.25") tall... it would fit in a flight case easily. For not a great deal more than your original figure, you could get this combination.
Geoff Tanner
www.auroraaudio.net
