This has been an excellent conversation, I agree. And you're certainly right that the circuitry used in most PCs to govern the CPU and support chips would not be designed to the same purpose as a clock that is intended for audio. While they are similar, they have somewhat different goals. But it's also worthwhile to note that it is not particularly difficult or expensive with current technology to design a clock that is both accurate and precise in audio terms.SouthSIDE Glen said:The only point on which I might comment would be the one about the exception being a flawed/defective clock. Maybe this is dancing with semantics a bit, but the mobo clock in your average PC-based DAW platform is not going to be what I would consider flawed or defective; at least not for it's designed purpose of clocking general purpose computer curcuitry. But it certainly isn't something I would consider to be operationally stable enough to call a quality house synch signal.
What's difficult and expensive is propagating that clock over a distance to multiple targets. That's where a Big Ben or other quality clocking device comes in handy. But even then, careful attention must be paid to the clock signal path - even more so than the audio signal path.
This is, after all, HOME recording dot com. Most of us are not at the point where we need to worry about a clock bus for our home studios. There are other ways to spend our money that will have a much bigger impact on our work.
