R
RobbieL
mr. president
The title speaks for itself lol. I was wondering what are the "ideal" (in quotes since theres room for variation) compression ratios are for lead vocals?
I'd say that, ideally, the rations are (1.1 to 1) to about (8 to 1).
Shiny vocals in the other hand can be achieved with the famous golden ratio. For a very sad or agressive song, a negative ratio might work well. And if you want to do something surrealistic you could try using imaginary ratio like 3,2+2i. For a more conservative song, I would suggest a rational aproach such as ratio 17/8.I totally agree. Compression use should be rationed like wartime chocolate.![]()
I think that compression is a notion that must be understood as a whole to be used properly (even though you'll still have to experiment before you get it to sound just right).
15:1 Like a boss.
Exactally, and with that attack.. again even at 2:1 that is a completely different animal than 20 or 40ms. Really need to consider the wave front's shape. There is (often) way more level differences happening on the front ends of things = more for the comp to see (react to.. and that's also where a huge part of the compression effect therefore style is going to come from. (..not to mention most of your livliness of the recordings living thereSorry we get a little snippy sometimes.
A good place to start (don't finish there) is 2:1, attack super fast (1ms?), and 40 ms release, and threshold where it's making a difference but not squashing it (this is straight from the Home Recording for Dummies Book). That is where I started and played to find the right sound.
But, of course you have to understand compression as a whole before it will do anygood. ...
