All,
I just took delivery of a very nice new Antec Sonata case for my DAW. Besides it's extremely silent operation, it has very nice appointments for loading hard disks and 5.25 drives.
However, in this new case - the drive cages sit just far enough away from each other to make optimum IDE connectivity a real problem.
Prior to purchasing the Sonata case, I had an ugly, heavy rackmount case that I finally gave up on due to amount of time it would take to do any quick changes to my hardware.
My drive config in that rackmount was like this:
IDE 1 Master - WD 800JB
IDE 1 Slave - Plextor 40/12/40A
IDE 2 Master - WD 800JB
IDE 2 Slave - DVD-R
I have always considered this config to be standard for optimum usage of the IDE channels during read/write operations.
Due to current cable length limitations in this new case , I have had to revert my config to look like this:
IDE 1 Slave - WD 800JB
IDE 2 Master - Plextor 40/12/40A
IDE 2 Slave - DVD-R
I have read scads of opinion that the config on IDE 1 could cause problems when recording due to the fact that a single IDE bus theoretically can only do one write operation at a time. Your thoughts? Am I even going to notice any difference in these configs? I would like to hear some solid opinion on this.
There is the option to go to a 36 inch version of IDE cables from Antec (Cobra series) and I know that 36 inches goes way beyond the IDE spec for cable length but I may have to go to this length to get an IDE cable with enough spacing between drive connectors to hook everything up right.
Anyone using extra long cables? Any problems? Any suggestions on shorter cables with at least 10-12 inches between connectors?
Cheers,
Cuzin B
IDE 2 Slave - DVD-R
IDE 2 Slave - DVD-R
Cheers,
Cuzin B
