Ok ok. So Im a bit of a whiner. A fusspot, drama queen even. Im all those things and I was wrong too.
This board rocks! It wasnt easy to set up........no it wasnt. But now it works!!! If you are using Cubase or any other ASIO platform set up should be easier for you. Cakewalk can be set for either ASIO or WDM. The directions tell you set Cakewalk up WDM but dont. When I finally tried changing CAkewalk to ASIO everything clicked! No latency issues or driver issues or static! The thing works great!! The pre amps are great, the effects are great. This thing rocks!
Ok.....couple of tips here for set up.
1. Make sure ALL defensive softawre is off for the install. This includes spy ware stuff too, not just firewalls and anti virus.
2. Do not follow the power up procedure in the book. Let the computer boot all the way up, then turn the mixer on.(that came from alesis by the way.)
3. If using the Cubase that came with it you may not have the set up problems I did. If youre using Cakewalk, like me, Dont set it up WDM like it says to. Go with ASIO in both the mixers control panel and your software. The drivers for ASIO are much more stable.
4. Make sure the board is set the same as the softawre. Either 48 or 44. But make sure theyre the same.
I should apologize to Alesis for bashing them here in my last thread. This mixer is very cool and I would recomend it to anyone. Ive already recorded up to eight tracks at a time with this baby with no problems. I wonder if they spent a little more time with the asio drivers so people would try the Cubase. It only supports four tracks though so that wont be of much use to me.
At any rate, once again I feel like an ass for ranting like a spoiled kid. Dont let my past thread sway you away from this unit. Its money well spent, and I imagine by the time more hit the stores they will have cleared up some of the set up issues.
Kudos to Alesis for a really nice machine!!!
