solo2racr
SUCK, SQUEEZE, BANG, BLOW
I've been using, essentially, Tweekheadz Rig #3 (albeit a bit better than what he suggests) for the last 5 years and my mixer's PSU just went out. It's a Soundcraft Spirit E8. No band here (just myself) so, this setup is just fine for my needs. I have been looking at different options and just not sure what to do. What I have come up with are....
1) Repair the PSU (a SMPS). Though, there is a FET that is no longer available and I would have to find it's replacement.
2) Build a new linear PSU. I have built a few guitar pedals and modded a couple amps so this wouldn't be a problem. May be cleaner power as well.
3) Replace the mixer. New ones are out of the budget at the moment so, looking at eBay. ( Mackie VLZ 1202 or 1402, Behringer Xenyx 1204 as suggested by Tweek, another Soundcraft Spirit E series, or maybe a Yamaha MG with the appropriate routing options)
4) DIY something. Get a 2 ch. mic pre and DIY the routing, A simple gain recovery stage on the monitor out and a few switches for signal routing. Mixers are overkill. All I really use are the mic/line preamps and some of the routing.
Sooo....on option 3, what mixer would have the better (I know, subjective) preamps? I'm not much on Behringer but, I can't ignore Tweek's suggestion either. I have only used a Mackie once and it was years ago. Soundcraft I know. Yamaha???? A total unknown.
Also, does option 4 have any merit? Tone controls are worthless. Aux send/return are almost worthless, though I can see the rare use of an outboard effect on rare occasion. It's pretty much, for me, just mic preamps, inserts out to the M-Audio 2496, in from the 2496 and the "tape out" to the monitors.
I have considered a USB interface and start, almost, anew. But I like the 2496 and it works fine.
Suggestions????? Opinions????? Come on, I know you have them!
