Here is some info on my computer I just got it.
10.2GB Capacity
5,400 RPM Spindle Speed
Number of Platters: 1
Number of Heads: 2
8.5ms Average Seek Time
Ultra DMA 66/33 support
Acoustic Noise Suppression Technology
High Speed Digital Signal Processor (DSP) based Architecture
7 way interleave OTF Error Correction
S.M.A.R.T. compliant
SSB™
ImpacGuard™
NoiseGuard™
AMD Athlon™ Processor 1GHz
Features:
1GHz
Nine-issue, superpipelined, superscalar x86 processor microarchitecture designed to achieve high clock frequencies
Multiple full x86 instruction decoders
Three out-of-order, superscalar, fully pipelined floating-point execution units, which execute all x87 (floating-point), MMX and 3DNow! And Enhanced 3DNow! instructions
Three out-of-order, superscalar, pipelined integer units
Three out-of-order, superscalar, pipelined address calculation units
72-entry instruction control unit
Advanced dynamic branch prediction
Enhanced 3DNow! technology
200-MHz AMD Athlon system bus (scalable beyond 400 MHz) enabling leading-edge system bandwidth for data movement-intensive applications
High-performance cache architecture featuring a split 128-Kbyte L1 cache, an integrated 256K L2 cache (external 512K L2 cache for Model 1 and Model 2), and a large dual-level, split Translation Look-aside Buffer (TLB)
Socket A for AMD Athlon™/Duron™ 200MHz FSB processors
95/100/103/105/110/115/133 MHz FSB
Auto-detects CPU voltage
Chipset
VIA VT8365 (KM133)
VIA VT82C686B
Chipset with build in S3 savage 4 graphics core
Creative CT5880 PCI sound chip (4 channel)
Memory
2 168-pin DIMM sockets
Supports PC-100 / PC-133 SDRAM and VCM SDRAM
Supports up to 1GB SDRAM
Supports only 3.3V SDRAM DIMM
Slot
1 x AGP slot supports 4x mode
3 x PCI Slot supports 33MHz and PCI 2.2 compliant
1 x AMR slot (reverse)
System I/O
2 x UDMA 100/66/33 bus master IDE ports on board
1 x FDD, 1 x COM, 1 x LPT, PS/2 keyboard, PS/2 mouse on board
1 x VGA (DB15), 1 x joystick, 1 x line-in, 1 x line-out, 1 x MIC on board
2 x USB ports on board
Power
ATX power connector
Power-on by LAN, RTC, modem and switch
Power-off by Windows® 95/98/2000 shut down and switch
Stop CPU fan during entering suspend mode
Form Factor
Micro ATX , 4 layer PCB (24.4*21.0cm)
Hardware Monitoring
Auto speed down and alarm when CPU overheat or fan failure
System voltage detect (Vcore, VDD, Vcc, +12V)
Stop CPU fan in suspend mode
Hardware detect and report Power-in voltage, CPU voltage and CMOS battery status
CPU/System fan revolution and temperature detect
BIOS
2Mbit Flash RAM
AMI BIOS with enhanced ACPI feature for PC '98 / Win '98/2000/Me compliance, Green, PnP, DMI, INT13 (>8.4GB) and anti-virus functions
IDE#1~#4, SCSI, LS-120, ZIP and CD-ROM bootable
AC recovery ON/OFF control
Auto-detect and report system health status
Other features
Suspend-to-RAM (STR)
Includes Wake-On-LAN header (WOL) and internal/external
Supports USB keyboard or mouse wake up
Includes 3 fan power connectors
