I would rather err on the dead side, only because I record vocals in the room. It is a 10’ X 12’ basement room with 7’4” ceiling and used to possess some nasty and loud early reflections. I made a few recordings and I could easily hear the ugly ringing sound and the echo. I have a big classical voice, and I like to be 6 – 8 inches from my mic… so the small room did not flatter my recordings.
What I did was put four 2’ X 4’ Auralex panels on the back 10’ wall, which is directly behind me. The foam along with a couch that’s on the back wall covers about 85% of it.
The two 12 foot side walls have 3 sheets each, so they are about 50% covered on the upper 4 feet of the wall and not at all covered on the lower part (stuff takes up part of the lower 3 feet of the wall, like my keyboards and a table with junk on it…) The wall that my pc / monitors is on has no treatment. Does this sound like too much foam?
The walls of the room have been filled with r-13 on one of the long walls and r19 in the other 3 walls (the 2 short walls are 6” thick to hide a support column, so r19 fits.) One of the long walls was built next to the cement foundation; actually it leaves about 8’ to a foot of a gap, so there is a good bit of space behind the wall (for access). The ceiling is a suspended ceiling with 2X2 acoustic tiles, and r19 between the joists above. The floor is thick carpet over a thick layer of padding over bare cement.
So maybe you can tell me, is the room doing anything for bass? I didn’t specifically build it to, but I don’t know enough about these things to know.
Anyway, the monitors sound TIGHT and defined now. The stereo image is much more precise then before. I thought the speakers just sucked because you could not pick out where anything was on the soundstage, but now things seem to fit right where they belong. The midrange sounds much more clear than before. Voices and instruments sound natural and crisp, and I can hear the details of everything. Before if 2 sounds took up the same frequency space in the mix it would be hard to tell where one ended and the other began.
Anyway, I would be very interested in what you think Blue Bear.
