K
KiFF BluEs
Hi, I have a few questions (no kidding?
1. I've been reading the Allen & Heath MixWizard 16:2 manual and it says this about it's internal effects:
2. Are you able to make subgroups on the MixWizard mixers? There are no subouts or anything. I'd need to make subgroups to make analog mixing easier, I only have 2 hands! (Or maybe I should try and get a digital mixer with automation.)
3. If I used an analog mixer with my computer based setup I'd most likely mix out of the box. However, if I wanted to mix ITB one day, could I do that without unpatching anything? In other words, I'd leave everything how it is and wouldn't use the analog to mix. I would mix/mixdown using the software instead, even though the mixer is hooked up.
4. (This kind of goes along with #3) If I had monitors plugged into my analog mixer will it only monitor my analog mixer or will it monitor the software mixer too?
Thank you
)1. I've been reading the Allen & Heath MixWizard 16:2 manual and it says this about it's internal effects:
Does that mean I have to patch AUX 5 to my recorder in order to record the mix with the internal effects?Can be configured in single mode (16 programs fed from aux 5) or Dual mode (8 programs fed from aux 5 plus another 8 programs fed from aux 6). FX are returned via ST1 to the mix, aux 1-4.
Thank you
