Ok gurus.. I could really use some advice on this one...
I bought a Delta 66 today, installed fine, works great figured out the patch bay and all that jazz. Now for the dilema... My SBlive... It still functions, the only trouble is when I play Midi tracks in CWPA9 the play out of the SBcard..(Obviously) My dilema is routing it out to the Delta, Because i am monitoring through it, and not the SB. I tried connecting the SPDIFs (SB out to Delta in).. And it sounds wonderful. BUUUUT I have to set the delta to 48khz... which leads me to believe once I am there I am stuck. meaning, if the drum track is recorded at 48 K so do the others.. And as far as sample rate goes.. is 48K Ok? what will I have to do with the mix down of the entire song once it is done?? If not 48 then I guess 44.1. I have a P2400 256M ram, don't think I am ready for 96K.... Any suggestions?
