MistaMash'dup
In Cubase SX 2, I cut an event exactly in half based on sample rate. (I looked at the "Length" value of the event, divided it by two, then moved the scissors to cut at this value.)
However, the event is not exactly halved. It's very close, and the difference between it being cut exactly in half and the way that it actually was cut is imperceptible... But, since I'm looping one of these halves, the difference doubles each time the loop is repeated. Over time, the looped event's timing diverges from what it would be if the event had been cut exactly in half.
I can tell this by doing the following: I place both the original event and one supposed "half" of this event so that they start at the same point in time in the project. I repeat the half many times in the project, and repeat the original event many times. Over time, the start points of the original event and every other repeat of the supposed "half" diverge.
This would not be a problem, except that I am compiling a heavily edited DJ mix in Cubase (sort of an Ableton Live type of concept), and was counting on the ability to be able to cut an event exactly in half, loop it, and be able to know that it will stay in time with the tempo of the original event that it was cut from.
Does anyone know how to cut an event exactly in half?
