i have the computer. i run reason, live and soundforge on it with
a midiman oxygen 8 as a controller.
the amd athlon xp-m 1.86 ghz is fast. i read on the net that it is the equivalent of a 2.5 ghz, but can't verify that.
i have made a reason track using some30 devices and the cpu usuage is around 40%.
the build quality of the computer is good, no issues with quality
Problems:
It only has 2 usb 1.1 slots. No built in firefire, although I think a higher end model does have the option.
The power shileding is poor. If you plug in the power supply, you will get extra noise if you are using a USB/audio interface. I've tested this on three separate units. You will have to strictly run on battery if recording or playing live, and the standard battery lasts about 2 hours.
I was using
the us122, but recently switched to an Echo Indigo IO and I'm very pleased with the set-up. Witht he Indigo, the package is complete. It is extremely compact, portable, and it's converters sound great.
I also did all the XP audio tweaks and the computer has functioned flawlessly, with the power supply noise being the only issue. If there wasn't the shilding problem, the computer would be near perfect.
Roger
