Johnrg
Guys,
I have an ART mic pre amp that has a built in analog to digital convertor.
This has an output level dial that increases the level sent out of the analog outputs and the analog/digital convertor. I usually go out of this unit digital SPDIF into my workstations spdif, however this has it's own gain stage as well.
I have real trouble working out the correct setting for thhe input / output levels of these three things:
(1)Input Preamp=Analog VU meters
(2)A/D convertor=Rotary dial with digital meters
(3)DAW spdif input with input fader and meters.
Here's what I am thinking - can some one correct me if I am wrong:
Step one - DAW Spdif input - set this at unity gain (odb)
Step two - Pre Amp Analog VU input - aim for peaks at 0db (especially drums etc) the odd over is OK seeing it's analog at this stage.
Step three - A/D convertor output - increase this so my signal hits the DAW's input meters at average about -18db. Peaks maybe up to -6db.
How does that look?
Is there anyway I can send a test tone/pink noise into the mic pre to set the out level of the A/D convertor at the correct place so I never have to chage it once set?
Thanks for your help
JohnG
How does that look?
JohnG
