true-eurt
Maneater
...on the B string saddle...I did a search and came up with a thread about string breakage...but the guy already filed down the burrs and still had problems with his strings breaking, here are some bits of suggested cause/solution offered....
Graphite powder for $1.50 and lubing up the nut and saddles.
http://www.acehardware.com/product/i...entPage=search
AND THIS....
Switch over to Graphite saddles and nuts.
http://www.graphtech.com/product_dis...nd=StringSaver
AND THIS....
Upon inspection, the string had worn a groove in the saddle, which was undoubtedly wearing the string the wrong way....?
How can I tell this?
But I did not find any instructions on filing...nor what type of file to use....so I Googled found this info.
Does this sound about right to you guys...?
1) You probably have sharp burrs on your bridge saddles. Files are not fine enough to fix this, especially if strings need to slide smoothly past with vibrato action. I recommend using at least 600 grit sand paper to smooth out your saddle depressions. Fold the sandpaper around the next smallest string (use an A string to sand the low-E saddle depression) and work the paper back and forth through the depression with a light pressure. Do the same for outer edges of the depression - this is where the majority of string breaks occur. When finished, this should have a slightly rounded appearance on close examination - don't over do it. I would suggest finishing this with 1200 grit paper, if you can find it.
I don't want to spend money on new saddles, if I don't need to.
Thanks and sorry if the info is here and I just didn't type in the right question.
AND THIS....
AND THIS....
