hongteck
I experienced the same skipping tracks as DaveO in his previous post
entitled "buffering" & after following the thread I'm pretty sure it is caused
by the DMA setting I'm suppose to have on my audio IBM Deskstar DPTA
7200RPM HD. However I have a problem because when I go to Control
Panel > System > Device Manager > Disk Drives > to check out the drive.
My HD does not have a DMA box to select. My question is how do I get it
to run on DMA mode ?
My system is a Abit BE6-II board running a Celeron 466 chip with
128 Mb Ram and 2 Hard Disks. The Abit board has IDE1 & 2, IDE3 & 4.
IDE1 is connected to my main Maxtor hardisk as Primary Master
IDE2 basically connects the CD-ROM and CD-RW drives.
IDE3 has my audio IBM DPTA 7200RPM HD which is supported by
Ultra DMA/66. I'm using the Highpoint Tech's HPT366 Ultra DMA 66
Controller driver.
Thanks in advance
Controller driver.
Thanks in advance
