Railway Surfer
Hi Guys,
I'm a newcomer to home recording, well recording in general! I've got an old Tascam Porta Two Ministudio (the big old one, not the newer smaller one). I just want to get some basic ideas down and pass them onto the guys in the band to learn before practice. I seem to be having a problem getting a clear sound. My guitar seems to distort very easily. I've tried turning down the volume on the guitar as you would with a valve amp but it doesn't seem to get rid of the problem. The VU meter isn't going into the red when I record, and if I turn the fader and or the trim down too far on the recorder then it's too hard to hear when played back. I have recorded a couple of tracks that came out really good but I can't tell what I did differently. Is it possible there is an intermittent problem or is lack of use a more reasonable explanation? Sometimes the track switches that switch between mic/off/tape need to be switched on and off or given a light tap to work. If cleaning is req'd, how do I do that, spray contact cleaner??? Any help or advice would be great, Cheers.
