Lopp
Ya know, I don't care how long you've been recording. I don't care about how anal you are about your speaker mic'ing techniques...
Don't ever assume that everything is set up the same as the night before. Especially if you have a stupid cat.
In particular, you may record a killer guitar track. Then using the same amp, but a different setting, doubled the track. Then using the same amp, laid down some killer leads.
Then you sit down to mix it and get the levels all nice relative to each other. Everything may sound soooo ballsy. Then you mix it down and burn a CD to check on other systems. Something might not be right.
Everything may be ballsy, but there is no brightness. Sure, the cymbals cut through, but there's something missing.
So you go and remix by reducing the bass guitar. Remix, etc. Sounds better. Still huge sounding, but very dull.
So you go and remix, reduce the bass again. Remix, sounds better, bass is a little absent, but it is just not a crisp mix.
So you go to remix and look over at your mic'ed cabinet.
The damn cat had knocked the mic out of place.
No wonder the guitars sounded huge but muddy.
Time to re-record all the guitar parts.
Not that that's ever happened to me.
