Chrisulrich
Member
Dear Anyone.
Depending on the answer to this, might be a follow-up question but for now - hear(!) goes!
I'm just hoping this doesn't sound too vague, because I'm trying to wrap my head around all of this mixing stuff. OK, if you've got - say - a real bunch of 23 real violinists in your back pocket, you prob. wouldn't need to alter the sound at all because it would be perfect from the get-go. But if you've just got the sound from a downloaded VST - I KNOW you're going to ask which one and I'll give you the list of ones I've tried if you want but I'm just keeping it hypothetical, so pretend you've got a VST called Bog Standard Violins - how much better than bog standard would you expect to be able to make it sound, using all the plug-ins at your disposal?
I ask, because I've spent the last 2 freaking days solid trying to mix a piece of piano and strings and trying to get it to sound like Kevin Kern, or any of the other piano'n'synth string guys all over YouTube. I've had tortured cats, neighing horses, gnats with well-tuned wings, fingernails on blackboards, strangled sopranos, all the above coming out of just about everything I've tried - what I've NOT achieved is anything LIKE the string sounds I've heard from 15 year olds with cracked copies of Fruity Loops on YouTube.
So I'm finally admitting failure - I can write piano and strings, I just can't mix the mutha - ah - dear, sweet pieces because I can't make the strings sound anything other than a bad joke. I'm not that much better with the piano, but in my hands the strings are awesomely bad. And I don't know if it's the plugins or the Muggins! I'm suspecting the latter, but it could be a bit of both.
So assuming the writer of this post doesn't have the resources to go and buy L.A. Scoring Strings in the morning - which VST/Soundfont/Anything would you advise me to download/buy (up to about £100 or very near that amount) to do Piano and Strings with and what with EQ etc., would you do to the output to make it sound at least vaguely as good as 150-listener youtube stuff? Right now, I'd settle for that. (If you assume from this I know as much about mixing as I do about flying like Superman, you'd be about right!)
Yours frustratedly
Chris
Yours frustratedly
Chris
