I recently wrote this article on how microphones work, and the differences between the 3 main common types (dynamic, condenser, ribbon). I'd love to get some feedback on it. Also I'm going to include a section from it in the post below, wondering what you guys think about my description of transduction, if it's easily understood by reading it, and if you think anything should be changed:
Electromagnetic Transduction Principle: In regards to microphones, electromagnetic transduction is simply a coil moving back and forth near a magnet. In dynamic mics the diaphragm is connected to the coil, and causes the coil to move when the diaphragm vibrates. The coil then starts to generate an electric current as it’s moving near the magnet, which travels out through wires as an audio signal. In ribbon microphones the diaphragm actually is the “coil”, but the same principles apply.
Electrostatic Transduction: Regarding microphones, electrostatic transduction is caused by the distance between two plates changing. These 2 plates have a voltage between them. The back plate stays stationary, while the other (which happens to be the diaphragm in this design) moves when struck by sound waves. When the diaphragm moves towards the back plate the voltage is charged. When the diaphragm moves away from the back plate the voltage is discharged. This configuration creates what’s called a capacitor. Since the capacitor needs a voltage to function, condenser microphones typically require either 48v phantom power or an internal battery, although some use other sources w/ different voltage.
Microphone Transduction
The way dynamic and ribbon microphones transduce energy is through the electromagnetic induction principle, while condenser microphones use an electrostatic capsule. As intense as it sounds, I’m going to attempt to explain it in relatively simple terms.Electromagnetic Transduction Principle: In regards to microphones, electromagnetic transduction is simply a coil moving back and forth near a magnet. In dynamic mics the diaphragm is connected to the coil, and causes the coil to move when the diaphragm vibrates. The coil then starts to generate an electric current as it’s moving near the magnet, which travels out through wires as an audio signal. In ribbon microphones the diaphragm actually is the “coil”, but the same principles apply.
