composition4 said:
...So.. If I have a recording (say, a single snare beat) and I set PhaseBug (which supposedly just delays the signal to achieve phase-shift?) to put it 38 degrees out of phase (compared to the original snare signal)- by how many milliseconds/samples would it delay it? How would the program quantify how much to delay it by??
Here's another take on all of this. I don't do much theorizing out here in the hollar so I'm coming in from some tools I play with and other forums where folks have discussed things of this nature.
A couple of things that have been mentioned, more or less (ref Rane):
phase angle indicates a value in time relative to an arbitrary crossover point (usually 0 degrees) thru which the periodic input waveform has progressed.
When two signals (ie input and output) have the same exact
time relationship to each other, they are said to be
in-phase
Changing the phase angle also changes the time value at any given frequency.
A
phase-shifted sine wave appears displaced in
time from the input waveform. This displacement is called phase delay (or group delay) and is [usually]
constant for all frequencies of interest.
Voxengo makes a tool that I think was modeled from a hardware box, however the Voxengo plugin is phase-linear:
The
PHA-979 allows "arbitrary phase shift to the program material. What is meant by the phase shift here is a simultaneous shifting of all frequencies across the active frequency range of the signal by the given phase shift value. This process does not harm the phase relations within the signal being processed."
Ih his forum at Voxengo Aleksey goes on to explain how phase angle relates to time in this tool:
http://www.voxengo.com/forum/pha979/849/ )
..."...For example, if you have a 64 Hz tone, its full period lasts 15 ms. So, 180 degree shift translates to 7.5 ms shift in time. 90 degree shift is the same as 3.75 ms shift. Phase shifting PHA-979 performs is pretty the same as splitting the signal to infinite number of bands and then time shifting each band for the amount depending on the band's frequency."
"The most obvious example of how phase shifting differs from time shifting: for example, if you want to time-align bass you will need to shift the track pretty far (several milliseconds). For the same amount you will shift the higher frequencies. By using phase-shifting you may shift lower frequencies in time for the same amount (several milliseconds), while higher frequencies won't be shifted in time by any considerable amount. Again, PHA-979 is *not* a delay unit. You may check this out yourself."
"By the way, if you understand the purpose of the phase invert switch available on mixers and mics, you may understand the purpose of PHA-979. PHA-979 simply offers 178 intermediate positions to this 'phase invert' switch."
Anyway - I think using
the PHA-979 tool and comparing it to results with some kind of track delay (I mentioned earlier) the difference should be obvious in sound. I'll have to check this out myself. As far as what a shift in phase angle has to do with time at any given frequency I guess you would have to calculate it since - even though it may be constant - time value is also based on frequency (obviously).
We don't normally think in terms of "I think I'll try a time delay of 0.02 ms at 2KHz to fix this" do we? What are we doing here again?
