Still problems.
Right now the midi out of the PC goes to the midi in of
Korg N1. The N1 is set to play channels 11 - 16 and sends channels 1 – 10 to its midi out. The JV1010 plays channels 1 – 10. The midi through on the JV1010 sends the performance info from the N1 to the PC.
The problem is that there is a midi feedback loop in this if I turn midi echo on in cakewalk. After thinking about it I realized what is going on. Cakewalk sends a note on to the Korg. The Korg passes that to the Roland, and also to the PC via the midi thru on the Roland. Cakewalk gets it and echoes it to the N1 via the midi out... and that goes to the roland and the PC starting the cycle over again. Nasty.
So I have to turn the midi echo off in cakewalk. Unfortunately without the echo when I press a key on the N1 it just plays some sound on the Roland instead of playing the sound on the selected track in cakewalk. Not good.
If the Roland could do the channel filtering like the Korg could, I would be all set… Cakewalk would send a note on to the Roland, the Roland would either play it or pass it to the Korg depending on the channel. If it got to the Korg it would be played, but nothing would never be sent to the midi out of the Korg so no feedback. The midi out of the Korg would go to the midi in of the PC, so when I press a key on the N1 Cakewalk would choose the channel the key press info would go to.
Unfortunately I can’t seem to get the JV1010 to do this. I don’t even know if it has this ability.
Is there a device that would have say one midi in and 2 midi outs, and send some channels to one out and other channels to the second out? This would fix my problem.
