I Am using Acid Pro 7 and I Am quite n00bish when it comes to the MIDI aspect of it.
I wish to use my Tascam DP-02 to trigger my MIDI tracks. I want to be able to press play or record on my recorder and make it play my MIDI drumtracks in Acid.
I followed the Acid help file and I was still unsuccessful. I Am using an M-Audio MIDISport Uno USB adapter for MIDI IO. The device is available in Acid.
There is very little to do to set up the recorder. It has three options Off, TKC, and MTC. I used MTC as the help file suggests and I tried TKC just for the hell of it. When I press play on the recorder the MIDI out lights up on the adapter. The device is sending out a signal.
Does anyone here use external devices to trigger MIDI in Acid?
