The Bolton "sound"
First, you will need a loose fitting blouse and tight pants, then you need a spray bottle of "tan-in-a-can", then you need hair extensions in the length range of "more than NASCAR, but not quite heavy metal". That should do it, but I would also suggest a variable speed oscillating fan, so you have options later in the mix.
