i feel your pain
I do my tracking and mixing in Reaper now, converted from Sonar, but up until now I had been using Wavelab Essentials 5 to do some simple home mastering on my final stereo wav mix.
Well, now with Win 7 and a few other things updated, Wavelab will not run, it scans plugs and just crashes. Steinberg (burns my ears to say that word) wants me to pay more money to install the "update" that is actually an "upgrade" to Essentials 6. In typical brilliant fashion, they dont even give me a way to activate it or license it. So I said to myself, "F******K IT! Stei******rg can s***k my a*******ss!" (Pardon my Spanish!)
So, the next obvious question becomes what other apps can I choose from that will do my simple home mastering? Mostly I just use Ozone 4, with maybe a touch of Sonic Maximizer or a Limiter, nothing dazzling.
Audacity is free but it doesn't really do plugins or have the versatility to burn a redbook spec cd for dup'ing, etc. I might check Izotope to see if they have anything like that.
What do you people use for this? Is there some other open source app out there that will do what Wavelab does and will let me use Ozone and burn discs that can be copied, etc....? A lot of people are hyping CD Architect, any users there?
Be nice to have something inexpensive. I'm tired of being drained by the upgrade machines so many vendors burden us with. That's the main reason I left Sonar to join Reaper......I can afford it.
actually the spanish would be a bit different
you can buy an all in one DAW and maybe a few addons if you have special needs that cant do. or you can get a whole bunch of free/cheap programs and spend more time manually controlling the work flow.
roxio or nero may burn the cds the way you want
but cd architect is the way to go imho for special cd burning
audacity can do a lot of editing
and they do have plug ins
unless you need something really off the wall
and if so you can write your own to do it
are you confusing mastering with mixing?
you can master with audacity although it takes more work than a full boat DAW
mixing is even more awkward with audacity but you could do it for free.
for quick and dirty cds for friends i use audacity and nero
sometimes i have to switch machines and use roxio
not sure why but suspect the blank cdroms dont agree with the burner on the nero machine
my real home studio , when i get it finished, is going to have sonar because of the steinberg crapola issues you note. i would rather have nuendo but not with a dongle price to pay.
i will add a scorewriter/notation program that you may not need.
i will add samples and softsynth you may not need.
then i plan to eventually get cd architect.
nero or roxio may do what you want.
if i have other special needs then i might get a specialised program to handle it. eg tough noise removal. simplify a lot of mixing FX steps. mastering? cant see any other program needed the way i define mastering. mastering would only be to match levels and perhaps a touch of eq. most everything will be done in mixing the stems not at mastering step.
to really answer the question: to simplify your home mastering dont get anything. get something that allows you to edit without being a hassle.
