Sir Trefor said:
What you should know, right off the bat, is that, first of all I don't even own a bass yet(I'm a guitar player who wants a fretless bass).
If you don't already have a bass, you should just BUY a fretless bass. Or buy parts from someone like Warmoth. You will be much happier with the results.
Sir Trefor said:
Second of all, I will perform this procedure no matter how much advisory I get against doing it(All I wanted was something like- "use this kind of wood filler to fill the slots...").
Don't use wood filler. Use Veneer. It gives surface which will actually last.
Sir Trefor said:
Third, and finally of all, although most of the people hear know more about musical insturments than me, I am an experienced woodworker, and I am confident that I can remove the frets without damaging the fingerboard.
This is NOT woodwork. It is lutherie. Though we do woodwork, there are a lot of very specialized skills in our business. This is one of them. If you are not experienced in lutherie, you WILL fuck up your fingerboard.
And if you are talking about using wood filler, your experience is in carpentry, not fine woodwork.
Sir Trefor said:
And why would you need to know where the frets are with a contrasting veneer? A fretless bass allows more freedom for intonation
No, the point behind the fretless bass is the BWAAA. Sure, there is some wiggle room for correcting intonation, but the intonation points are always within a few thousandths of an inch of where the fret would be. Lined fretless is easier to play, particularly if you are just starting.
Sir Trefor said:
Forgive me if I seem hostile.
-Trevor
And forgive me the same. I hate to see instruments fucked up, which is what usually happens when amateurs try and do my job. Trust me, nailing together some pine furniture does NOT qualify you to work on guitars.
Here is a little math for you, by the way, on what it would cost to make a fretless bass from Warmoth parts.
Pickups (Bartolini's) for J-bass - $140 (at least, that is what I charge. You can probably get them for less if you want).
Finished J-Bass Neck - $201-211 (Maple neck/Rosewood fingerboard, Satin or Gloss finish, Gloss recommended as they are harder)
Finished J-bass Body - $320-330 (Alder or ash)
Bridge - $30
Gears - $30
Total - $721-741
Try finding a bass as good as that could be for less. You won't.
And that is using premium parts. You can get bodies and necks which are quite good (though not as good) for quite a bit less.
As I said, the information is out there for how you remove frets, but it is a really bad idea to do it yourself. You do not have the tool, and it doesn't make sense to make it (you can't buy it) if you are not doing this full time. You also do not have the experience, no matter what woodworking experience you have, unless you are a luthier, in which case you would already know how to do this.
Always remember, it takes us twice as much time to fix your mistakes as it would to do it right in the first place, which means it costs twice as much.
Light
"Cowards can never be moral."
M.K. Gandhi
