Just to add my 2d (or two cents, if you will).
Many years ago I worked in the aircraft industry in the field of electronics.
In wiring up aircraft with cable lengths going from cockpit to tailplane in large commercial airliners, in the main we used crimp connectors NOT soldered connections.
A properly crimped connector, i.e. with the receptacle designed for a specific SWG/AWG wire, and using that gauge of wire and a crimping tool correctly set for that gauge too, the result was a connection of outstanding performance. Typically of lower resistance than a well soldered joint but, more importantly, outlasting a soldered joint, under similar vibration and stress, by many, many times.
The crimping tools we used were much like the mechanism inside certain torque wrenches used for tightening bolts on a cylinder head.
I think they used a kind of knee joint that gives under a certain preset pressure.
They were taken away from us on a regular basis for testing and replaced on a yearly basis as I recall.
But then people's lives are at stake if a joint fails in flight.
Silver plating makes little difference to audio cables as, at audio frequencies, the signal travels within the wire not so much on the surface.
It does make a difference when talking RF.
To make a slight difference solid silver would be necessary.
Copper and silver have a very similar resistance, with silver just coming out ahead.
Good cables (not necessarily exotic ones) often use copper of greater than 99% purity anyway.
Gold plating of connectors is only useful to guard against corrosion (gold is of higher resistance than copper), but BOTH plug and socket must be similarly plated.
Plating just one of the surfaces is largely ineffectual.
Its primary purpose is to prevent deterioration of connectors that remain in place for extended periods, as is often the case with Hi-Fi.
For live use, connectors with an extremely hard yet conductive surface are best as with Neutrik TS, TSR and XLR.
As the joints are remade every gig the wiping action of insertion and removal cleans the joint.
The construction of the cable (e.g. good screening) and its capacitance have more effect on its performance than resistance, but not at audio frequencies, unless you're a bat!
The insulating jacket can be shown to have some effect on performance too, but again is unlikely at audio frequencies.
Lastly, for all those "subjective", "golden ears" people.
Your ears can be fooled into hearing what isn't there at all.
Take a good look at this site about the McGurk Effect, and be honest.
McGurk Effect Audio-Video Illusion | Mighty Optical Illusions.
We only think we hear what we hear.
Regards,
John.
