H
Han
I as reading a closed thread, Miroslav got me back to HR. A closed thread about analog and digital. I've been reading this kind of debates for more than ten years now and I'm done.
I am a studio owner and an audiofiel, moderator on a hi fi forum and I know all about it. We did a number of ABX tests, double blind tests and one of them was testing the vinyl record of DSOTM by Pink Floyd, which contains frequencies of 76 khz.
So some 25 people with hi end setups at home were in my studio and we had a Thorens recordplayer, a 24/192 convertor and a 16/44.1 convertor set up. Output levels calibrated within 0.1 dB and there we went.
There was a moment when somebody said: this is the recordplayer for sure. Wrong, it was the 16/44.1 convertor. So the conclusion is that no one of these +/- 25 audiofiel peeps was able to hear any difference.
For instance: I have an analog board of 3.20 m wide with a couple of hundreds of the same knobs in the same places. If you look at that surface and you look some 0.5 meter further for a while, you will get another picture. It seems that an extra dimension comes up. You know this is nonsense because the board doesn't change, but you will see it.
It's the brain that's doing it, the eyes are camera's. The ears are microphones, the brains makes the sound out of it and that's the problem.
I do record fully analog, to a 2" machine and I'll tell you why: because if a vocalist begins to scream very loud into the microphone, the VU meter will reach the red numbers, but you won't have any problem at all. And I like to see the reels spinning and I like to have the big board in front of me, with the nearfields on the bridge and the lava lamps.
(that should *not* have happened given the power level, I guess even Scandanavians lie sometimes
) so I am listening to woofers at the moment. I should at least pop 'em open and bypass the crossovers because the woofers are capable of 5kHz or so . . . but I haven't bothered yet. I'm actually enjoying it a bit.
