nl553 said:
WOULD LIKE TO KNOW WHAT YOUR REALLY NEED TO GET A GOOD RECORDING (ON A LOW BUDGET).
This is a classic... without the normal sarcasm I might add here (hey, you're new!) You have to spend money to get to a level of "good", otherwise live with "bad" to "mediocre" recordings.
The big-boy's facilities cost well into 6-7 digits to create excellent recordings.... obviously, you don't have spend THAT much, but for sure you will need to spend more than "low budget" would indicate.
OK....... lecture aside... the X-55 is pretty much a song scratch pad tool, so your recording quality is already behind
the 8-ball with it, but anyways... you don't mention what kind of mics you have but I'm assuming you didn't spend a lot of money on them. Big problem. Cheap mics sound like crap - but there is an exception - a Shure SM57 or SM58 (around $75 for the 57 and $100 for the 58) -- good solid workhorse mics that give a good sound on many sources.
Next, the x-55 is going to have pretty bad pres on it - you shold consider buying a small external mic pre (hey - I told you, you're going to have to spend some money to get to even "modest or mediocre" sound quality!) ART has one for around $150.
OK - that would improve your recording signal chain a little bit. You still have a problem with mixing and tweaking - the x55 doesn't leave you much in mixdown flexibility, so it's even more important to get the sounds recorded half-decently.
For non-microphone sources, again run the keyboards thru the mic pre and make sure you're recording the signal hot enough to get around the limited s/n ratio of the cassette multitrack format. NR only reduces tape hiss, it will not reduce noise in your signal sources, which is why you wouldn't have heard a difference.
The next level up in terms of sound quality would be to migrate to some flavour of digital multitrack, or go the computer recording route. But the cost outlay of course is higher.
You don't get something for nothing - there's no big conspiracy where the studios spending hundreds of thousands of dollars on gear to get excellent sound could really have gotten the same results for less than a grand!
You gotta pay a bit to play!!!
Cheers,
Bruce
