Hi, i am in the process of adjusting my MS16 and i can see how the tape fluctuates slightly up and down on the heads and right side guide. Not enough to get off the guides or rub them hard, but as i look closer the tape wobbles up and down causing amplitude variations on the audio signal. I've tested it with the calibration tape. I have a rerubbered pinch roller from Terry. Any ideas what could be wrong ? could it be that the pinch roller is wobbly ? even if it has jsut been rerubbered ? when i press the pinch roller hard (to increase pressure) the issue seems to go away of be reduced. Both the pinch roller pressure and tape tension have been adjusted as per the manual.
Will appreciate any help, hoping someone with more knowledge will chine in.
Thanks,
Felipe
Thanks,
Felipe
