Here's how I did it. I use 2 Zoom R24's (bought for $200 each on craigslist) linked. The preamps kinda stink* on the R24's so I take direct out from an Allen and Heath Mixwizard 2 (you can do the same thing if you inserts on each channel on your board). Everything is close mic'd and goes through board (only vocals and very little guitar, and maybe some kick, go through the mains) so:
Kick Drum - Beta 52
Snare -
SM57
2 Toms - Digital reference kit mics
2 over heads - Oktava MK-012s
Guitars
Senn E609 (the buzz in the right is from the amp. He never has had a buzz until we played this place. Oddly enough, the PA was as quiet as I've ever heard (no electrical noise)). I'm the guitar on the left channel and I mix in a signal from my pedal (it's a stereo output pedal, one goes to the amp, the other goes straight into the board).
Bass and vocals are direct.
All EQ is flat except for whatever I need to adjust the vocals for the room (it is a live gig after all). Vocal mics are SM 58**. I EQ almost every channel when it hits the DAW (I've been using Presonus Studio One V1 Artist, fwiw)
Compression on everything in the DAW and then mix to taste.
*When I record a practice I use the built in pres just for ease. Much easier to carry an R24 than an Allen and Heath Mixwizard.
** Way too much bleed on these mics. I have a Senn E 895 that's just as bad. There is a Samson mic that looks like a 58 that has excellent bleed cancellation. Can any recommend anything else here? Thanks again everyone!
