dabluesman
I just got a PODxt and two TRS cables. I plug the TRS cables into inputs 1&2 OR 3&4 on the BACK of the Omni and plug the other end of the cables into the left & right outputs of the PODxt. Then I plug a guitar into the PODxt's input, turn the PODxt on, open Delta's mixer software and start jamming. The signal lights on the front of the Omni light up but I see nothing in Delta's mixer, however I do get sound through the headphones. I've got the faders set hard left/right, should I try putting them in the middle? I had a similar problem before due to me trying to TS cables instead of TRS, thats why I got TRS cables this time. I ended up unplugging the Omni and hooking back up the original Delta 66 breakout box. It works fine this way but I wish I could get it to work with the Omni. It does work through the mic inputs on the FRONT of the Omni, but I would prefer the line level inputs. Has anyone else had this problem and fixed it. If setting the faders to the middle position (-5 & +5, I think) doesnt work, I dont know what else to try... different TRS cables? Thanks!
