Aoresteen
Help with Cables! Balanced output to unbalanced input
I need to connect the outputs of my mic pre-amp to the inputs of my Delta 1010LT card.
Inputs 3-8 on the Delta 1010LT are unbalanced RCA jacks.
Outputs of the Nady PRA-8 eight channel preamp are 1/4" TRS balanced.
Each cable will be 30 inches long.
The tip of the 1/4" TRS connects to the center of the RCA jack.
Should I tie the ring to the sleeve and connect it to the outter contact of the RCA jack or should I just connect the ring to the outter RCA contact?
Or do I float the ring and just connect the sleeve?
Thus far I've only sent unbalanced audio signals to the RCA jacks on my Delta 1010LT (worked very well) but now I have to send mic signals to them for the drums (dang drummers!).
I called Nady but they are stumped and asked me to send them an email they could pass onto 'higher'.
Thanks!
Thanks!
