ches1
I'm posting it here since most of them cables will end up in my Delta1010, wich inputs accept either a Balanced or Unbalanced singal
1- is there such a thing as a pair of RCA to a pair of 1/4"TRS cable??
my turntable's preamp output 2RCA(1left, 1right)while the Delta1010 use 2 1/4" inputs(1left, 1right) for stereo recording and I'd like to get the best signal possible
2-is there such a thing as a TS to TRS cable??
my C300 compressor outputs an Unbalanced signal(tho it is mentioned in the manual that it does not suffer the common 6db losses)I didn't found any TS to TRS cable on the net but there is one showed in the manual, heres the link, page 13 or 14http://www.tcelectronic.com/media/C300_US_070307.pdf
3-can you send a mono signal over a TRS cable??
I tried to make it as simple as possible without forgoting important details,
any answer will be greatly appreciated.
Thanks in advance,
Peace.
Thanks in advance,
Peace.
