Pops and clicks?
Are they in the recordings or ONLY during playback?
Time for the obligitory system description questions:
What sound card?
What computer? (motherboard, ram, as much detail as you have)
What Operating system? (Win2k, XP, Win98se)
If the "snap crackle pop" thing happened in the recordings, look to your sound card as the culprit.
If the pops and clicks only happen during playback, try this:
1.) Open Acid
2.) Select OPTIONS
3.) Select GENERAL
4.) Scroll to the last choice at the bottom of the list
5.) Put a check in the box for "USE SLOWER UPDATES"
6.) Now click the Audio tab
7.) Click ADVANCED
8.) Go to RECORD LATENCY and be sure its set to "AUTOMATICALLY DETECT AND OFFSET HARDWARE LATENCY"
9.) Click APPLY and/or OK and close ACID
10.) Restart ACID and test.
Any improvement?
Some pops and clicks occur during screen redraws but are not part of the ACID file or recording. They don't show up when you render the project. Try it and see - if the pops and clicks are in the recordings or the rendered file, it's likely a souncard related issue.
Z
