Booda
Master of the Obvious
I have 2 tunes w/ files that were recorded at 44.1 but the PC sees them as 48khz
Story Line...
A session I recorded last week w/ only 7 tracks. (4Drums, Bass, 2Keys)
I used a Template in Cubase SX that was set to record at 48khz 24bit.
After 2 jams I realized that my Lucid Converters were set at 44.1... so I set up another Project file w/ the correct settings... so the last 2 jams were recorded at 44.1 and are fine.
Mixing
The files play back fine through the same chain as long as the Lucid is the Clock... but when I Mix em down from 48 to 44.1 stereo file, they play too fast.
My Solution (so Far)
I tried importing the Wav. Files into a new project, w/ the project setup as a 44.1 24 bit.
When importing each file Cubase asks if a new file should be made, I say Yes. There is an option to convert the Sample Rate when importing, I say No.
So... the files show up in the Pool as 48khz but the project is set up for 44.1, it all seems to play and sound fine.
When I mix it down it also sounds fine, since I'm not changing the sample rate.
So what's the problem? I don't know... does this sound like the best way to go about this? Do I have other options?
Thanks for any help or explanations,
B.
Story Line...
Mixing
B.
