stainlessbrown
I have a TSR8- a PPS-2 synch and a Digi 002R/8.0 PTLE
I've striped the tape- signal level is good, no bleed onto 7- The PPS-2 see's the synch signal
PT sees the "Motor Control" under Midi, and it doesn't give me any errors that it can't communicate with it (although I had to assign it on port 1 , and move my Euphonic surfaces to 2 and 3 for that error to stop happening)
Synch is set to "Machine chases memory locations"
Session Set-up window shows
Session start: 00:00:00:00 (and I've tried setting it to 10 seconds , 20 seconds....)
incoming time is 00:00:00:00
time code rate is 30
feet+ frames 24
SYNCH setup and time code offsets
MMC 00:00:00:00
THE LINKbox is checked to Satellite 00:00:00:00
sample offset 0
Time code settings- choices are 'Using Peripheral' a box which has an 8 (default... and i've changed it)... and last "Jam Synch" none of the 3 seems to change anything
I can't find any other places to change settings?
anybody see anything obvious that I'm missing?
feet+ frames 24
MMC 00:00:00:00
sample offset 0
