saxman72
I actually have two problems
I don't know if they're related or not...
First of all, I'm running Cubase VST/32 on Win98
Ok, so a while back I un-installed McAfee virus stuff and installed Norton virus stuff. I think the un-install removed some things that my computer still needed! I always get three messages when I start up my computer:
1. cannot find CTL3D.DLL windows needs this file to run C:\OPLIMIT\OCRAWARE.EXE
2. ocraware.exe
(X) Access to the specified device, path, or file is denied
3. desktop
/!\ Could not load or run 'ocraware.exe' specified in the WIN.INI file. Make sure the file exists on your computer or remove the reference to it in the WIN.INI file.
I usually just 'enter' through these messages and just about everything on the computer works fine. The problem occurs however when I record new audio on Cubase:
Once I make a new audio recording, that track doesn't play back. I have to select/highlight a different track and then MAYBE the one I just recorded will play. But then, the track I just selected won't play. And to top it off, sometimes a track once selected won't play anymore even if I select a different track.
The first time this weirdness happened, I got an error messsage when I closed Cubase. I was in a hurry and didn't write it down. Unfortunately I haven't been able to get the error message to pop up again even though I'm still encountering the same problems... from what I remember, it said something like:
"synsopos error caused by Cubase..." (I don't rembmer the rest)
In my amateur sleuthing, I found that synsopos files exist in the Windows\System folder and in the Cubase\Backup folder. However, no synsopos files exist in the main Cubase folder. Should they?
Yikes! Long post and I don't know if this'll make sense to anyone, but I hope it does!
Anyone know how I can remedy one or both of these problems? Ask me questions and I'll answer them the best I can.
Thanks so much in advance!
Saxman72
I don't know if they're related or not...First of all, I'm running Cubase VST/32 on Win98
2. ocraware.exe
3. desktop
Saxman72
but yeah... hopefully they can help me out!
