help making cds flow
  • Thread starter Thread starter ivebeentired
I
ivebeentired
OKay, i recorded two songs that can go together on a cd very well, but when i make the cd theres a pause inbetween the songs.
is there a way to make it so they would flow into eachother?
The term you're looking for is "crossfade." What program are you using to burn your discs?
Most burning programmes will automatically add a gap of around 2 seconds. There might be a way of changing the setting if you check. if you use Wavelab you can set the exact amount of time between each track or as madaudio said you could put both tracks in the same wave file and perform a cross fade and then place a marker inbetween the two tracks so CD players will treat it as two seperate tracks.
what Cd buring programs recgonize markers. The markers are setup in the CD buring program correct?
