yeah, i've got the XR model... none of that fiddling around for me when I can pay someone else to...
Ok, so if I send a SMUX II signal into the lightpipe, it wil laccept and love it as it would its child, and record without issues?
The reason I ask is that I used
an Onyx 800r with mine the other day, and had a play with the 96k operation.
Mics->onyx->lightpipe->hd24xr
Set sync to optical, it stayed steady, but the Sample Rate light was flashing- if I'm reading everythign right this means that the HD24 wasn't detecting the ADAT HR/smux bit. Further investigation shows that the Onyx uses SMUX II out...
So, does SMUX II set the ADAT HR bit to "1", or do only Alesis units do that?
Or is there another reason that the sample rate indicator was doing its flashy thing?
(Please note: this was NOT the "Source" light {optical} flashing, it was the "Sample Rate" light).
