Steve,knightfly said:If you're trying to do this with absorption, good luck; the 1/4 wavelength of 120 hZ is just over 28 inches; meaning, if you want absorption optimised at that freq. you'll need it to be 28-30 inches away from a solid boundary, and if your 120 hz problem happens in more than one axis the trap would need to be located in a common corner in order to do much.
Do you have an actual problem at that freq, or is this a theoretical question aimed at improving general knowledge of acoustics?
Steve
