C
Centropolis
I want to use 4CH mode and record my acoustic guitar using the built-in mics, and then plug in a condenser mic into INPUT 1 and record vocals at the same time. INPUT 2 will not be used.
Is there a way I can pan the signal from INPUT 1 to BOTH left and right channels in the second WAV file? Because it looks like if I do this, the vocal will only be in the left channel. Or the only way is the edit the files after by copying the left channel to the right as well and then mix it after? Is there a way to do this without editing?
