Guitar through Tascam 122....
  • Thread starter Thread starter rxQueen
rxQueen
rxQueen
the volume is not high enough. I raise the volume a little and I see the overload light blink
also, I can't seem to hear much pick strokes? wtf?
why?
I'm running a v-amp 2 through it.
I thought I was recording everything at 96000hz and 24bit but I just checked the properties for the device through control panel and boy, was I terribly wrong. :mad: :mad: :mad: :mad:
like so...
how do I change it to 24bit and 96khz? :mad:
thanks
Try throwing more juice from the v-amp into the us-122...then adjust the rest from the tascam
The us-122 only supports up to 24bit 48khz..and to adjust it..you will need to setup your new project in whatever application your using to those specs.
Also i would adjust your latency slider to atleast 512
