austinm08
the pigeon knows the way.
So I have a problem when using my patch bay with my Digimax LT.
Here's the signal path:
1) Mic
2) Female XLR to Male TRS snake
3) TRS patch bay (Neutrik NYS-SPP-L1)
4) TRS to Male XLR cable
5) Presonus Digimax LT going optical into:
6) Digi 002 control surface
This rack gear is racked in my homemade case and each unit is NOT isolated from each other, in that there is no insulator between the unit and the rackmount rails attached to the case. Is this the cause of my problem?
One thing to note, is that if I don't plug the TRS from the snake completely into the patch bay (enough for the tip and ring to make contact, but not the sleeve... I think), the signal passes through just fine. But as soon as I push it all the way in, there is an obnoxious hum and no signal seems to pass through.
One other observation, is that if I bypass the snake and patch bay and go directly into the Digimax LT, there is no hum.
What would be causing this?
1) Mic
