ricecrispies
Member
When I record through my desktop computer (via a Scarlett 2i2 which seems to work OK when connected to my laptop), I get a lot of unwanted hisses and fizzes consistent with a ground loop. If I am just recording with my microphone or my bass plugged directly into the audio interface, the sounds are below the level of hearing, but clearly visible in the level meters in my DAW, which of course becomes clearly audible with certain effects. However if the audio interface receives a signal connected to another device with its own connection to the electric mains, such as my bass amp (via a DI box) or my digital piano, then the problem is bad enough to make any kind of recording impossible. I've managed to reduce the volume of the noises as far as the bass amp goes by (slightly dangerously) isolating it from ground, but I've not got rid of the problem altogether.
I assume that there is a faulty or sub-standard component in my computer, but I need to know which one it is so that I can replace it. Is it likely to be the motherboard or the power supply or something else?
