This may be an old topic, but I really come onto this site to pick up best practices. I've been recording for a long time, but I'm still more of a musician than engineer. I love getting little insights into how my favorite recording was done or how it was mixed. The above topic in my title is something you do with compressors that I read about way back when and have used at times, but I've wondered how often it was used on certain records I use as references. As opposed to something else. Anyone? You can use a with outboard eQ in the same way as a compressor if if has the sidechain function. The DBX graphic EQ I had, was made for recording studios and had sidechain. There still seems to be lot of companies making graphic equalizers. ZZounds and 8th street have lot of examples made by several different companies. Only a few parametrics and the one I looked at made no mention of sidechain. (I'm assuming most know what that sidechain is for) I have a Mackie Board with 4 different bands of EQ per channel and generally my approach is to cut moderately for the most part and if two tracks are fighting with each other, I cut one in a certain frequency and maybe boost the other track slightly at the same frequency. The trouble I had with ducking with a compressor is that is generally was noticeable (to my ears) An example would be to duck the
acoustic guitar slightly whenever the the lead vocal came in. the results are always subjective. But, with an outboard EQ, with Sidechain, with the same tracks, the guitar would be eq'd subtly, whenever the lead vocal comes in. this isn't common anymore?
