Freudian Slip
OK, up loaded a new file. If this doesn't work then I think it's time to format and reload the comp
This is a work in progress. Not sure how I am going to finish this out, It only has two verses but it's 4:20 long. Might just extend the solo and come back into the chorus?
Anyway, the drums are getting re-tracked and the section of guit under the solo. Let me know if you have any problems with the file.
Trying to mix in a largely untreated room
Finally getting moving o my control room after 2 years.
I usually steer clear of political songs but, this just came to me.
What we’re trying to do here
Is build the world a new fear, so we’ll stay strong
We’ll give you all a new cure
And just enough to keep you hanging on
We’ll give our selves some freedom
Take away the line ‘tween right and wrong
When we’re the arms that hold you
You will find that all you had is gone
And you’ll be
A slave to me
And you’ll be
A slave to me
We create the victims
And we’re the ones that know how to hold them down
We pick the words you can’t speak
Fill the air with tension all around
We’ll engineer your down fall
So we’ll be there to lift you from the ground
You’ll put your faith in us when
No signs of your religion can be found
And you’ll be
A slave to me
And you’ll be
A slave to me
Finally getting moving o my control room after 2 years.I usually steer clear of political songs but, this just came to me.
And you’ll be
A slave to me
And you’ll be
A slave to me
And you’ll be
A slave to me
And you’ll be
A slave to me
Hopefully I will have more time to work on this soon.
