JTC111
Active member
No matter what combination of mics I use on these instruments, I can't seem to get any sounds that I'd call "musical." Anyone else using any of these?
I came here FIR help ‘cause I thought you BEECHES know ALDER shit there is to know, especially you ELDER members. But instead of LINDEN me your knowledge, you all is actin’ like a bunch of ELM-Os. You all must think you is a bunch of stinkASH CHERRY Seinfelds or some shit. You best not LILAC some crack whore with her TULIPS wrapped around some REDWOOD for the rock.
You best CEDAR light before I lay some SUMAC down on your ASH. I’m a cold mo-fo and I chill like it’s TUPELO zero. My motto is if some BEECH ASH ho try to nip you, JUNIPER right back. So EUCAPLYPTUS joint I gots in my hand, pardner. My shit is so fine and so POPLAR, I give a DOGWOOD.
So BEECHES, you know where OLIVE but you best know if you come around my hood, I WILLOW you. You ain’t getting in my house ‘cause I told my brother and HEMLOCK the door. If you is comin’, you best keep it on the down LOCUST the peeps I run with will tell you what I always say, “Someone try to burn me, VIBURNUM right back.” So check yourselves, fools, or I MAPLE a gun and put a cap right in your SPICE BUSH!
Man, forget YEW people!
We have a winner! That's as forest we should go with this one...
Have you tried the Blue Woodpecker?No matter what combination of mics I use on these instruments, I can't seem to get any sounds that I'd call "musical." Anyone else using any of these?
